hi! received the kit today, and just finished the soldering, and it works
am I the first? I hope, the sd-image is up soon. is there a instruction
for the case?
so, my fastest built... everything is fine, one IC misses the ICxx description,
everything else is fine, wonderful work from sonic p.!
I hope to see a lot of different firmwares, like mpc like sample players etc.
keep on soldering
andi
You are fast!
I'm currently assembling the SD card image.
should be up in the next half hour.
But here is the instruction for the shruthi case that is very similar
http://www.flickr.com/photos/fcd72/sets/72157625039474678/
:bz
after doing some tests and playing arround:
this thing rocks! can´t wait to connect my other boxes to it...
:x
the drumsets are very very nice, the algoritms are very versatile, a lot of options etc.
I am VERY PLEASED
i am pleased like never before.. just couldn't find an emoti to express that joy.
mine has no case and is covered with dog hair, all part of stress testing.
I'm really eager to hear what you gonna do with it!
I painted my OLED PCB black using a marker
Ofcourse there are 2 mistakes what i made: OLED is to high and enclosure don't fit & mix button doesn't fit (i must remove it and solve once again), but this 2 bugs are not bad: LXR rulez in my studio
Ouuu jeeeeaaaa
(some photos: poterski.com/implant_sonic_potion_lxr.zip)
Already tried to desolder the OLED and have not been successful so far so I'm curious if you will be able to fix it.
What's the part number for the buttons? I'd like to have black ones only...
order numbers for the caps are
mouser
Black: 611-21125
White: 611-F0202
Grey: 611-F0204
Red: 611-F0203
digikey
Black: 401-1215-ND
White: 401-1216-ND
Grey: 401-1217-ND
Red: 401-1218-ND
found in the BOM
https://docs.google.com/spreadsheet/ccc?key=0AgngFqfjdS0odDdqLUk3N0IxS19Xd0JRa01pVEpoNFE&gid=0&output=html
connector (took the plastic thing away in the end, then it was fine)
and one forgotten LED, it was late...
but easy enough to do with a good soldering iron. The preparation of
the kit and the instructions were excellent!
the LEDs are not updating the status (even with new Firmware).
probably also a grounding thing since it is just a minimal setup with
just a headphone amplifier. I noticed the cases of the pots were not
grounded in the build, right?
the process. Perhaps some parameters shouldn't morph in a linear way at
all?
should be enough amperage (it´s inside the manual)
