As far as I know Adrian is working on it. I've send him the ,dxf files from the PCB and a trigger IO to take measures. But he was quite busy with all the MI cases lately. So I do not know more than you
I spoke to Adrian a few weeks ago and he said he was still working on the LXR cases. I think he's trying to finish up the MI Ambika official ones before moving on to another big production.
I think this request is too specific for mass production Afaik Adrians plan was to make an enclosure with replaceable backpanels for the trigger IO. But I think for something like D-Sub connectors the best route would to just use the normal backpanel and utilize a jigsaw.
Assembled the LXR into case and need to make some changes. Need to leave more room for inserting PCB.
Front plate for case is 3mm aluminum and bottom is 1mm steel. @loderbast, no custom holes for one piece. You could cut 3 CV holes together to make a D-Sub.
On back there is power switch under the power plug and CV outputs. There will be cover plate for CV, what covers the holes and print for CV, if you don't use them.
Print on upper plate and on back side for I/O.
I have to check the prices, but perfect result with fastenings depends of coating. If end result will be powder coating, then PCB fastening will be replaced with press spacers
Front plate fastenings will be replaced against flush head screws. If front plate will be anodized all screws will be flush heads.
I have two front plates and two bottoms without coating. Going to bring one front to anodizing tomorrow and try some colors. Also maybe try some color for bottom.
It looks big on photos, but not so big in real life.
looks really nice! will you sell them via Mutable Instruments or via Sonic Potions? would be soooo nice to have the options to choose between a case when you order a kit!!! My preference would be to be able to buy a kit from Julian with your case in one order, hint hint. any info on pricing?
Soo looking forward building one of these bad boys! Cheers, keep up the good work.
any chance to do a version with hole for a d-sub connector on the back to have the trigger i/o ports directly in the modular?
C
NICE!
let me know when we can order
Cheers,
C
I can let carpenter make some wood and check how it looks.
Lets first finalize this and look that in future.
Are there by any chance better/bigger pics available?
and, totaly oftopic, what does LXR mean?
but here are the links
http://forum.sonic-potions.com/uploads/FileUpload/cb/7178981aa6ba41441bdaa4f746ec37.jpg
http://forum.sonic-potions.com/uploads/FileUpload/b1/9b753f02fb585d575a92e6fe0bae4d.jpg
LXR is just a play on eLiXiR to keep it related to potions
