Hi all,
I just finished the assembly of my LXR and want to share my experiences Overall, the build is very easy. However there are a few things which are a little bit tricky to handle, especially if you are a newbie to soldering.
Following tips worked for me, i hope they help you too.
Nr.1: Use the provided bubblefoil as your building- /soldering underground. This will protect the enclosure from scratches and prevent resistors, screws etc from falling over the table. Also, you dont ruin your kitchentable if you accidentally produce tin solder splashes (your mom /dad / boy-/girlfriend / husband / wife /whatever will thank you xD).
Nr.2 When it comes to soldering the resistors near the USB jack, cut the wire first, then add tin solder carefully. this way the USB jack can be placed plain to the board.
Nr.3 If you have some jumpers laying around, do not solder the bridge in. Instead, solder in a pair of jumper pins and connect them with your spare jumper. This way you can add a power switch later without having to (de-) solder on the board again.
Nr.4 Aligning the LEDs is the trickiest step in my oppinion. Put them in, then rotate the board at 90 ° and solder 1 pin. Now bend the LED until it stands vertical on the board. Now solder the second pin.
Nr.5 After soldering the LCD connector, "carefully" remove the plastik spacer and mount it upside down. this way, the u-profile of the spacer leaves more space for tin solder bubbles on the surface of the board.
Nr.6 Just in Case you dont know how to update the firmware (didn't find anything with forum search): Load the binary on the SD card and put it into the slot. Now press and hold the encoder right from the display and power on the LXR. you can now observe the firmware update via LCD and the sequencer LEDs.
Some suggestions for the next batch:
* the LEDs near the voicebuttons should be moved a little bit ahead from the switches.
* In my case, some of the switchcaps wont stick on the switches. Maybe caps from another source would fit better.
Regards,
Nasrudin
I think I will include some of the stuff in the assembly instructions.
but the other points are good hints.
I'm trying to put an assembly instruction for the case online this week! so far the cases i've build di not creek or need excessive bending to screw together... :-/
I never had a quartz fail before... this was really a hard one. But I'm really glad you finally got it working!
On the 2x4 header it is quite obvious, but on the 2x2 header you could put the jumpers on like this || or like this =, whereas the 1st option would just short out the 2 output channels and not produce any sound.
Completed LXR today - my first self build, feeling elated as I chew on victory candy.
Some feedback, probably more relevant for noob builders like me:
1. The mysterious 'bridge' at the very beginning - yes, it's just a bit of wire that you trimmed from a resistor or something - there's no context for this in the build info, it's kinda assumed that you know what a bridge is, I don't even know now (and don't care :0 ), except that it's just a piece of wire soldered across two points - hence 'bridge' - gettit? (I'll include a nice picture of a real bridge in my FINISHED post later).
2. There's a lot of stuff in the build guide about getting the display straight, fiddling about with the black plastic thingy, trimming leads to make sure the display lies flat etc etc - I worried and spent too much time on this and can't understand why? In the end I'm sure I used too much solder on the connector pins, didn't push the black thingy down far enough, and my display definitely does NOT sit flat on the board - but guess what? It looks great, is perfectly (I mean perfectly) readable, and rocks! Am I missing something? Will my display mysteriously fail or something later...
3. The one place I had trouble right at the end was with attaching the main board to the female connectors because I hadn't fixed them flush to the board at the beginning. This is an early step and should be emphasised in the build guide as one place where you definitely DO want the parts to be straight and flush. I ended up getting out the desolder braid out and having to coax one of the connectors into a straighter alignment with pliers (not pleasant) - even now I'm worried the main board may be under stress because of this...
4. The case - it would be nice to have a sticky link to some assembly instructions - I know there's a link somewhere in the forum already to the MI cases but after searching for 20 mins I gave up and just used The Force to figure it out myself, it's not hard, see below.
5. The case - there's some advice about 'keeping it loose' on the forum here - this is very important - in my build most of the stress was coming from the back panel where the various in/outs, power, usb etc have to be lined up with the panel cutouts - chances are, if your a noob like me, some of your in/outs etc may be a little squint - but trust me, as long as they are not off by a mile, just using a little patience and keeping the case screws/nuts loose, you will be able to prise the cutouts over your connectors then tighten up - overall I'm extremely pleased with the case - although I did get a strange assortment of panels which I'll post pics of later
Yum - this Victory Candy tastes gooooood!
thanks for taking your time to write your comment, very appreciated!
2.) the problem is that if you use too much solder the display will be too high to fit under the enclosure afterwards. already had a customer who had to resolder the display when he wanted to assemble the enclosure.
3.)added a note to install them completely flat.
4./5.)added a dedicated illustrated step-by-step guide to the website http://www.sonic-potions.com/enclosureAssembly
The new assembly guide is currently in the proofreading stage and up soon.
