Hi everybody!
I actually record my shruthi thru a line enter and my
lxr thru the microphone (all minijack) in my "inbuilt" PC soundcard. And
that's not very good, especially the mic enter. So i wondered what are
you using to record your gear, and which soundcard could you recommand
me for under 200Eur (new or used) and why. I found lot of advices on inetrnet but most of the suer use their soundcard to record guitar and mics, Thank you!
Edit: They are class compliant, so they work also with an iPad without problems.
My suggestion for you would be a used M-Audio ProFire 610, should be available on Evil Bay for around 200 €. Very sturdy interface, with absolutely reliable drivers. Preamps are not really fancy, but they work. And no fucking USB, Firewire for the win !
Keep in mind the US 122 has only 2 inputs (this means 1 stereo input) which not very much. I don't know what you are up to, but it can't hurt to have more channels available. I guess the LXR won't be your last piece of hardware...
Maybe look for something like a used Focusrite 18i8 - should be possible to find it for 200 EUR. It has 8 analog inputs (this means 4 stereo inputs) + some digital ins.
NO! Here is a good description of MIDI: http://entertainment.howstuffworks.com/midi1.htm
I think i will stand for 2 inputs. For the win 7 compatibilities, it's seems to be awfull with older products (like us122) but it's seems there is solutions
just.. LXR -> usb cable -> computer
just skip the entire audio interface, like roland does with the aria, elektron with overbridge, virus with TI.
you get my drift? 2014 stuffffff audio interfaces are sooo outdated ;P
FOr the LXR and audio thru usb, it's seems someone on this forum try to implement this but no news since.
I nedd to turn the input gain a his max to have something. And its noisy! The only thing i came accros to record the lxr is to put the lxr in the aux input monitors, get a correct volume and reinject it in the soundcard input. Seems i need a pre amp before the sound card, Do you use pre amp or the out volume is correct in your lxr?? THanks.
EDIT SOLVED i have to use mono jack
I use an MOTU 828 MKIII, and te sound of the LXR is really punchy :-)
the MOTU includes a reverb and nice compressor :-)
regards.
