As a result of lack of experience, and a really bad soldering Iron I might have screwed up a bit. I did since bought a good Iron and the last part went smoothly but still, I might need help.
1. I think I damaged some ofthe RR6 traces, I can't find a shematic on the site, my question is on which leg of the switches should the pull down resistance be hooked, I think the way to go would be to put individual 10 ks to the ground, three of the led seem to act weirdly, don't stay put, I think that's for the button 9-10-11 but not entirely sure, I'm not home right now, would that make sense that switches around those are linked to the Network RR6? some of the little plates that you solder on are actually lifted, I believed I could connect directly to the switch leg.
2 On the first test I didn't get the chasing, nor blinking going when I pressed start Nothing happened. Most of the led seem to be behaving normally, except those mentionned in 1 but I'm not sure, should every led light up by any button I press? If that's the case there's more problems, the voice ones are working, the substep ones as well, and the one that is on at startup as well, but all the start, record, pattern, etc dont react, but I have to say that last night I didn't have a sd card, so I wasn't expecting any sound, just basically pressing all the button. Any idea where to check first? The display and the encoders seams to be acting normal, but yeah I'll have a better idea when i read the manual, and I actually try to make sound, Just tough i'd throw in where i'm at in case you happen to know what's going on.
I'm not too much in a rush, is there any shematics somewhere? would help a lot in troubleshooting, hopefully I didn't ruin it all, I'm confident that I can fix this. I would rather have a unit not so clean looking than start all over again with a new PCB ($), cause nothing is fried, the IC don't heat up, and the voltage checks are alright, so probably little things
Thanks for the help.
Pierre
1. yes, buttons 9, 10, 11 are linked to RR 6. You can find the schematic easily in the assembly instructions. There is a link: http://www.sonic-potions.com/sites/default/files/documents/FrontpanelSchematic.pdf
Have a look at page 6/7 of the schematics.
2. I think, you need the SD card for properly testing this.
This indicates that the mainboard is working, too.
So the problem should be around the start/stop button group.
here is a list from the wiki where all the buttons are connected:
each of the 165 ICs controls 8 buttons. the groups are the following:
So you should look around U10 for the start button.
here are 2 images of the start button connection. one shows the 5V power supply, the other the connection to U10 and the 10k resistor network.If all buttons in this group (U10: Start, Rec, Shift, Voice, Perf., Step, Load/Save) are not working, the error is probably located around U10, not the buttons.
U10 is the last IC in the shift register chain. So please check the following connections:
you don't have to remove the socket.
normally it is enough to just reflow the solder (just re-heat it until it melts)
If you can't find the button/led replacement, let me know and I will send you one.
Congratulations!
here are the switch contacts used for plug detection
and the upper right pad labeled "S" (Sleeve) is GND
This is viewed from the top, where the buttons and the display is.
you can measure if the jack is busted (which i doubt. just leave the LXR tunred off. Insert a cable and measure continuity between the tip of the cable and the signal pin from the jack. Do the same for the GND pin and the sleeve of the cable.
I would also measure continuity between the signal pin of the jack and the corresponding mainboard pin.
Normally the mainboard outs should work. Each mainboard is tested before I send them out.
No. Only the bottom right pin has signal.
continuity between the upper 2 pins is normal as long as no cable is plugged into the jack
Here seems to be the error. If you have continuity between the lower right pad and the upper pads, your output is shorted to GND. If you remove the mainboard an measure continuity again. Is the short on the front or on the mainboard?
I would think on the frontpanel. Maybe have a close look at the soldering of the jack and the left mainboard connector 'P2' Maybe the soldermask got scratched off and the pin is shorted to GND?
top 2 pins have signal, yes.
And both are connected.
Are you using a SD card and have you loaded a preset sound?
Just to be sure it is not set to stereo out and the panning is all right
Just a single mono cable inserted into jack 1?
So either the connection from the codec over the dual jumper to the pin header is damaged or one of the channels of the codec stopped working...
these are the traces from the codec to the pin header.
maybe measure at c20, pin1 if there is a signal there.
