This thread is intended to gather feedback about the pioneer kits.
Problems with the build? Any problems with the packing? Missing parts (I hope not!)?
State it here!
Or did everything went well and you just want to tell me I did a good job? :-bd
For firmware bug reports please use the bug report forum.
free routing.
each voice can be routed to stereo1 or 2, L1 or 2, R1 or 2.
I've found a bag of chrome coloured switch caps so I'll use them for this one.
now it's time to do the aluminum housing. (or polished brass with wooden ends?)
brass? like this?
I'll start with the aluminum first
... which proves how good the instructions really are
unfortunately i did not win another victory candy:
Congratulations for the successfull build loderbast!
This mutable lingo just does not cut it here!
but that sounds a lot like some roleplay game
I removed the USB jack from the connectors section and added it after the 10k+220 resistors.
the order from the instructions was not a problem at all.
the only thing, that was a bit hard to reach was the encoder pins, after already having the audio jacks in place.
regarding small to big components.
I tried to follow this rule, but for each side of the board independent.
Pattern changes for example will occur on the end of track 1.
I know about the 'lost sync' pronblem with changing track lengths, but I don't know what to do against it.
Syncing to the master track only makes sense if they have an equal track length. Otherwise they will be out of sync after 1 bar again (the beauty of polyrhythms). Further, syncing would introduce a discontinuity in the pattern. One could try if it gives satisfying results to check if a track has the same length as the master and reset it's position to zero when the master track resets at the end of a pattern.
At the moment the only way to re-sync them while playback is active is to change the playing pattern.
After a pattern change all tracks start at zero.
PS: congrats on the successful build!
maybe this is something (some of) the unused step buttons in performance mode could be used for...
like for having a button to restart all tracks2-7 on the next One on Track1.
or each track having its own restart button.
i guess it must be testet, how usefull this is, but i imagine it to be nice when playing with polyrythmic stuff (which i love) to be able to controll when all the paterns start together again.
