It would be great to eventually be able to load and save individual voices, rather than just being able to save kits... So you could select the snare from one kit and the hihat from another move it into a new kit, or just spend time working on getting individual voices right, save them as an individual voice, and share them or construct kits from them later. This would also make it easier for us all to share voices that we've built. I'm thinking loading could work like this:
- hit load/save button
- hit individual voice button that you want to load
- screen displays voices that are compatible with the voice button
--- gives you the option of loading that button's voice from a saved kit or loading an individually saved voice
To save a voice, hit load/save, hit the button for the voice you want to save, hit load/save again, navigate to "ok". Maybe there could be an option to save the voice into the same button position in an already saved kit.
As discussed in the transient/sample thread, it'd be nice to save the samples with the voice, but there are issues with wearing out the flash - if samples wind up being read from the SD card though, this would seemingly be possible.
Also, it'd be good to save voices as discrete copies rather than as references to one copy of the voice so that making a change to a voice in one kit doesn't change that voice anywhere else...
Maybe it makes sense to be able to select categories for each voice.
This might help to find specific sounds later.
my electribe has a "sample" mode, where i can tweak and tune samples, then overwrite or save new. it'd be stupid awesome to be able to crank out 5-6 kicks one day.. a few snares another day.. then, obviously join my individual "drums" into kits.
I think it should be not too hard to implement for example a "load only snare" function.
Not sure if it would be better to introduce single sound savefiles (snare files, kick files etc)
or just load the single sounds from existing kits.
when loading directly from the other kits you would not have to save the single sounds first.
on the other hand if you really go crazy and create just 20 different kicks it would probably be easier to introduce the single sound files than having 20 kits where just the kick is good...
hmmmm... I'll have a look into the code how it would be done in the best way...
kits where just the kick is good..."
Yes, i'm quite this kind of guy...
I like to be able to load all at once, a all-in-one solution, but also, when i am working on a pattern or a kit, if i come with an interesting sound, i wish i could save it for later, while keeping on working on my current pattern/kit.
And sometimes (often), when i focus on a sound (a snare, for instance), it happens that i create several nice snares, not fitting with the global kit i'm working on, but that i will want to save for later use.
Maybe it is possible to add some entries in the load menu.
This would be really great and will give us the ability to shuffle existing kits or to share individual voices.
I would like something like:
when on load kit page - e.g. press SHIFT + SNARE - rotate through your drumkits - only snare would change
Note that I had to change a LOT of code in the load/save menu to get this working properly, so the function of the knobs in these menus is somewhat different.
The firmware and full details are in:
http://www.brendanclarke.com/files/LXR/
read the readme! there are a number of additions/tweaks beyond just this!
Has this been updated in the firmware yet? Is it possible to save single sounds as presets?
I don't have an LXR but am thinking about buying one.
