Bug report: MIDI Channel starts a 0 which means...
The MIDI Channel parameter starts at value 0 (zero) after the first install which means the knob below don't act on the value until you choose to change the value with the encoder. After you've chosen a new MIDI channel with the encoder you can use the knob below the 'ch' parameter but you can't choose 0 again, which I guess i ok. Though it would be nice to choose omni too just for convenience when using the XLR with a computer.
ANother thing, the 'ch' parameter isn't mentioned in the Menu options table in the manual at 5.6.2. Might be a good idea. :-)
Cheers!
  • This is on version 0.21
  • i think this is just a wrong value in the global settings savefile on the SD card image.
    Try setting the value to 1 and save the settings file.
    this should fix the problem.
