PLEASE HELP with saving the "MIX page" LXR settings (FW: v.37 -BrendanClarke-)
edited November 2016 in General
Hi there!
This is my 1st post here. Been reading up quite a bit though while building my first LXR. It's been a great experience and I enjoy the sound of the machine very much.
That said, I just can't wrap my mind around saving settings under the MIX PAGE. Perhaps there's a way to do what I am trying to accomplish, but I don't se it yet?
My goal is to use LXR as a drum module in a live situation, but without having to set up following parameters every time i turn the LXR on/off or change kits.
My issue is being unable to permanently store the following settings found under the "MIX page":
-sound outputs (so that my kick is output on, say, L1, snare on R1, clap on L2, etc...)
-notes (so that kick is always on, say C0, snare on E0, etc..)
Is there a way to permanently SAVE these settings so that any KIT can be loaded without them being changed?
If yes, please be so kind as to offer a step-by-step saving procedure.
Thanks!
  • Have you tried to save your kit using 'all' in the save menu?
    This should also store I/O routings.
  • I will try that and will report back!
    K
  • Moebius, thank you so much! Your kind suggestion seems to have moved the issue in the right direction!
    I have successfully saved my settings under a KIT, using "ALL" save function, and now I can access those setting by loading a kit.
    However, after I chose another (existing) KIT, I had to once again manually change both the MIDI note and the output settings of each part to a desired state.
    Is there such thing as "GLOBAL SETTING" so that no matter which existing kit I load, the MIDI notes and output assignments remain?
    Cheers!
  • There is a global settiing! I think it is called "setting" in the save menu. But I fear that midi notes are not included, because they belong to the patch.
    I switched to the type "all" completely and save everything in this format, which works for me.
    I am not shure about the other types like "pattern". Maybe you could try that.
    But have in mind that the type "all" always overrides all parameters.
    I hope this helps!
  • great, thanks! you're right about "settings" not saving notes and outputs, but this is good enough!
    cheers
    k
