I recently had problems with a failing midi in jack. I decided to change it, meaning I had to remove the display which during the process broke in some way so it was just glitching. Changed it as well, works fine. However now it syncs to midi until I plug in any audio cable which kills the sync completely. Restarting from master clock doesn't help. Any idea what could be the problem? Some kind of ground loop? Short circuit somewhere?
