Hmm.. the Shuffle parameter, as set in the Pattern params seems a bit subtle to me, even at the maximum value. Is there any way to make it a bit more pronounced? Maybe there's another shuffle setting I'm missing. I quite like having the ability to push a pattern into near chaos. Might be a niche requirement, mind you.
Also, it might be fun to have the shuffle go 'both ways', i.e. have every 2nd 16th note be pushed back by a variable amount (as is currently the case), or pulled forward, for a different feel?
a|x
I just not had the time to bring it back
The way clocks are handled internally had to be rewritten to accomplish tight sync with changing tempos.
You used to be able to shift a note all the way to the next note before. Thats the way I would like to have it again.
