I've been trying to wrap my head around the voice architecture. The manual is great and it give me a good idea of how everything is connected, there's still parts I don't understand. Since I'm a guy who needs to see things to know how they work I've made a chart of the 4 different setups there is E.g. taking section 3.1 and trying to match it with the parameters under section 3.5.
http://thehumancomparator.net/tmp/lxr-voices.pdfHave it gotten it all right? Or is there something I've missed?
i'll print those out when they are ready.
i am not sure if yyou got everything right, but i think you can check the editor if you got everything
In the manual under section 3.2 it looks like the noise goes through the filter, but the oscillator does not. Then I don't understand the MIX function under the OSC. It must be the mix of the filtered noise and the oscillator? If so, then page 2 in my document is wrong
Edit - Made some changes to the PDF in the first post. Modulation is dashed and the snare is redone.
Could you make a version with white background, too?
Thanks a lot!
And the spelling error has been fixed! Thanks for noticing
Just noticed: Below Osc2 in the Clap and Hihat Page it should probably be "G2" instead of "F2"?
Greetings!!
@Controlvoltage Thanks! Fixed it.
