Hi all,
I recently built my second Penrose from a kit. The first one, that I built a couple months ago, works great. The second one works fine when first turned on, but after a few minutes it stops working (lights out). If I restart it immediately, it will shut down after a second. If I let it sit for a while, it will stay on for a couple minutes before shutting down. I noticed that the voltage regulator gets very hot.
So far I've tried reheating all of the solder joints that I could reach without removing the front panel. This did not change anything.
Does anyone have suggestions where I should look for the problem?
I had one penrose here for repair where the tantal was inserted the wrong way round and it resulted in an overheating and shutting down 78L05.
