Stupid question! How do I save???
edited February 2016 in General
I have tried multiple times to save patterns and cannot for the life of me figure it out...
I press the load/save button. Use the encoder to change where I want the pattern saved, change the text, go over to the OK and press it. A bunch of numbers scroll as if it is doing something and then when I try to load the pattern. It is empty. No sounds, no patterns.
Help!
Is there some sort of memory protection ???
  • The procedure seems correct, but something is apparently wrong. Does saving other things like presets and settings work?
  • Is the sequencer running, while you try to save?
    I also ended up with same empty patterns while the sequencer was running.
    But is was not reproducable.
    When the sequencer is stopped everythink works great for me!
  • Played with it again last night and now it seems to be working.
    Very strange.
    Does the machine always default to drum kit 1 and an empty pattern when first turned on? Or can this be changed?
  • edited February 2016
    Very strange.
    I am happy, that it's working now!
    No, the LXR starts up with an empty pattern and you have to load a new pattern first.
  • Ok thanks.
    By the way lxr with a bit crusher and eventide space is just killer!
    Sprinkle some sh101 and.... Bliss!
