Voice FM, wav s0 value problem
Hello everyone,
I have a problem with the LXR:
When I go to edit wav in voice FM, from s0 value the sequencer crashes, forcing me to reboot.
Does anyone have this same problem? Is it fixable?
And a question:
There is a possibility to solder a power switch on lxr?
Thank you.
  • OK, I solved the problem on the voice wav: when LXR went to load the sample s0 crashed because the sample was too long; raised the pitch and then shortened the champion, everything came back fine.
    The question remains whether it is possible to install a power button ;)
    Thank you.
  • Yes I had same problem when I select my 's17' in FM...sequencer stops and must reboot LXR. I thought about a wrong filename or ended sample memory...
    Do you know how can I indentify s17 sample in my sample folder? In which order LXR load samples?
  • I think samples get loaded in alphabetical order... but I'm not 100% sure.
  • It was the samples that are too long. Once pitched up and reloaded, everything is back to normal.
    And Yes, I finally added a power button. Thanx Julian for the help ;)
