I've have a n00b question about the Trigger IO. Having never played with CV really before I'm wondering what the use cases are for it? I have the trig board and a Microbrute. As far as I understand it the LXR can send a clock signal for timing and a gate (5v pulse) signal for triggering notes. If I plug this into my brute does this mean every time the LXR plays a note it can trigger the Brute to play a note as well? Do we get some pitch signal for the brute as well?
Also I believe the gate can trigger the brute's sequencer so if I record a sequence I can get each note played in time with the drum notes.
Is that right? Are there any other use cases? The above results in the brute overlaying sound on top of my LXR sounds which seems a pretty limited use case in general.
Perfect sync.
Quite the chain really. Midi from tr8 to xoxbox to lxr then midi out from that the my modular midi to clock module. And the trig out as above.
In a project I worked on two years ago, where we used different sensors including a pulse-beat one, I used the LXR to sync to a person's heart beat and then produced two clocks from that and various triggers for the two modulars we were using. www.kvsu.net/senxor
