Hi, sometimes the modulations on the LXR are confusing me. For example, i have a LP Filter fully closed on one track, then i set up the LFO on this track to open the Filter, full mod amount, but nothing audiable happens, also not if i play around with offset settings and so on. The target and the track to be modulated are set to correct values.
it also happens with other parameters on the machine, is there something i´m doing wrong? i found it to happen quite erratically, any help welcome
thanks!
edit: also if i get the lfo to work, offest seems to not do any actual offset, it´s not possible to open the filter from closed to fully openend with an LFO, please help
Attention!
The modulation scheme differs from most other synths in the way it
Also, offset refers to a phase offset of the LFO on reset, not an amplitude offset. From my (very very limited) experience so far with the LFO, it doesn't seem like you'll be able to use it to do what you wantmodulates the target. The destination value is multiplied with the LFO
value. That means the destination value is always modulated between its
current value and zero. It will never be bigger than the original
parameter value, so modulating a parameter that is set to zero won't have any effect!
cheers!
I rather like the way modulation is implemented. It might not be the most intuitive off the bat, but you also never need to worry about saturating a parameter.
Ah if this is indeed true then the LFO is much more useful than I thought. Since the manual regarding the LFO offset says:
