Guys, I've had my lxr for a few months and it is my main piece of kit. However I tend to read the basics and then get on with playing. I now want to load multiple patterns for the pattern sets so I can switch live, however on reading the manual I haven't got a clue how this works. Any ideas. I was under the impression you could save 8 patterns and switch them in performance mode.
If the sequencer is running when you switch pattern data by loading a .pat, performance, or 'all', the currently playing sub-pattern will keep playing until changed manually or with a PC MIDI message.
I don't think there is a way to copy sub-patterns between pattern set data, but you can always save the pattern set and kits separately.
Can't see anything in the manual about this.
I think some repeat/next settings (shift-select button while in perf mode) and 'pattern change reset' (global menu) can cause the pattern to change on the next bar after load. I tend to only change patterns manually.
Hope that helps!
