I have been building a Penrose. I feel like a fool, but I can't get it working properly:
- Note on/off LEDs work
- A CV in doesn't do anything
- The 4 highest notes change the pitch when turned on/off
- When one of the other 8 notes is turned on, the pitch turns to the same very high tone
- The trimmer does not seem to influence the pitch
Checked:
- I'm sure the big capacitors aren't touching anything, clipped everything close by
- Can't find solder bridges
- Diodes correct orientation, current flows one way
- IC's have correct orientation
- Checked schematic, it seems that row3 is only working ? But now what ? Paths of rows 1-3 from Atmega to other board all seem ok
- Checked all resistors with a multimeter. Here's when things get strangs, the 100k resistors measure this:
r7 99k
r20 100k
r2 51k
r9 51k
r14 104k
r15 99k
Checked and double checked resistance and color coding. How can this be ? Please assist, any ideas ?
