hi
i had a quick look but didn't find what i was looking for , so apologies if these have been asked elsewhere
ive had my lxr for a day , and its more instant than the rytm , seems easier to dig around , assign lfo's to random parameters . it works really nicely and seems good to get such good feedback / updates from julian and the other guy doing custom firmware (sorry , i'll dig out your name ) and everyone else on the forum.
1 . can i swap between normal / custom firmware with no issues in terms of patterns/sounds , or do i need to commit to one of them as additional parameters are in the custom firmware ?
2. if i add my own samples , do they "appear" when i turn machine on , or do i need to reflash the firmware ?
1. I never had problems, but you should backup you SD card before.
2. From the wiki:
44100 * 16 = 705600 bits/sec = 86kBytes/sec
So at 44,1kHz you only have about 5,69sec., but drum samples are usually very short.
Of course, make sure to back up the files on your hd periodically! I never have enough time to test all possibilities 100% in my fw
about morph... short answer is no. patch morph works differently than the lfo's for parameters. there is however a midi assign for morph in my fw, so if you have something that can generate a midi lfo...
