I'm having trouble figuring out how to load patterns onto the 8 select buttons for performance mode. Whenever I load a pattern it always loads to select button 1. How do I load 8 patterns?
Hi Satori, Welcome When you load a 'pattern' file, you load all 8 patterns in the set at the same time. If you've only been working with the first pattern, the rest are probably just blank in all the files you've saved. There isn't currently a way of loading to only one pattern in the set, but you can copy and paste patterns between those 8.
So select an empty pattern, sequence it. Do this for all 8 and save. Now if you load a pattern set. They should all be filled with the patterns you created.
You can not load 8 different patterns. Only a set of 8.
