Penrose Programming Success...I think
Anyone else use AVR Studio 5 to flash their chips?  It seems so easy and my module seems to be working.
I set the fuses according to the github directions and then on the "memories" tab there are two sections to load a file; "flash" and "eeprom".  I loaded the quantizer.hex file to the flash section and it loaded.  Are there any other steps needed or is that it?  Like I said the module seems to be working.  Do I need to load anything into the eeprom section?  What is the difference?
Thank you
  • no that should do the trick.
    you don't have to programm the eeprom.
    zhe eeprom is used by the software to save the pattern during power cycles. so if the module is working you are good to go :)
  • Thanks. I actually did two now and both are working. I've been sitting on these for a while and decided it was finally time to try and program these chips. Great module. Thanks again.
