switching os when the lxr is booting
edited June 2015 in General
i think it would be a nice feature to switch between different os when the lxr is booting.
so the owl and the 0.35 could be coexist on the sd....
can some one do this?
thanks
  • Not as easy as putting both files on the SD card.
    The Firmware is stored in the flash memory of the mainboard.
    It only reads the file from the SD card during a firmware update.
    It would need a software modification so that both OS versions are stored in the flash memory and the bootloader then decides which one to boot.
  • i can imagine that it isnt just shift the os on the card.
    however the possibilities to switch between os can be great. e.g.one os for sound design and another to perform with the sounds.
