LXR building problems
edited June 2015 in Troubleshooting
Hi, I have built the lxr but i have 2 problems with it:
1) some times the lights switch off;
2) when i turn to 126 the second voice filter frequency the sound stop.
i think i have solded something wrong inside, could u tell me what to fix?
thank you guys
  • I haven't the knowledge to debug LXR built. But, reading your post, I ask myself what you mean by "some times" (when?) "the lights switch off" (all the lights? the LCD too?) "the sound stop." (all the sounds? the sound of voice 2?). More precisions could help to identify the problems.
  • 2) when i turn to 126 the second voice filter frequency the sound stop.
    what filter type?  if it is a Hp filter, maybe that's a reason?
  • Lights switch off?
    Does it happen when you move the power chord?
    regarding the filter. Which filter type?
    is it on all presets?
    If the sound engine is working in general the filter should work, too.
    It is all software after all. So this can not be caused by a soldering error.
  • the problem with the filter is with all filters, also with low pass sometimes appends when i turn the knob to 126 and sometimes when i turn it to 127, the sound stops or starts to do strange things. I really don't know what appends.
    I've noticed another thing: when i use the follow mode at the beginning of the sequence the first doesn't repeat and goes direct to the second also if I select 1 or 2 repetitions.
    they are all problems that don't affect the working of the lxr, i can avoid them by paying a bit of attention but they're annoying me.
    I think i have damage the pcb when i soldered. it was the first time i used a solder so could happen
