MIDI Sync not working
edited June 2015 in General
I just bought a used LXR, and it seems that MIDI synchronization is not possible either via DIN-5 connectors nor USB port. I just set BPM's to 0, and nothing happens when I start the external sequencer. I would be suspicious about a bad connection of the standard DIN connectors or the optocouplers, but the fact that USB MIDI is not working either leads me to think that it may be a software problem.
I'm pretty sure that nothing's being filtered, although the options in the Global menu don't match at 100% the ones in the User Manual.
I also tried to sync a Volca Beats from the MIDI Out of the LXR and it didn't work either.
Anyone has had similar issues?
  • the wiki manual is a bit outdated.
    on SHIFT+Load/Save, Page 2, there is an option called RXF (RxFilter)
    Set it to all.  Set your BPM to 0
  • Working!
    I figured out that RXF was indeed the Rx filtering, but I assumed that "off" meant that no filtering was being made...  :\"> My fault.
    Thank you very much!
  • Im amazed i could help, im wrong a vast percentage of the time ;)
