synth engine fantasy to-do list (updated June 3 2015)
PERF - add master volume and a clipper in the menu
OSC-add a crossfader between OSC/CLICK
        -On Kick, let 1-127 = Hz  for tighter kick fundamental control.
MOD-add attack , add hold
FM-Add coarse _and_ fine, ratio/freq toggle (essential)
       -Remove user samples from FM section (they will more than likely end up as noise)
       -add instead a few single cycle waveforms (like on the tx81z for example.)
       -Add its own envelope, separate it from MOD.
CLICK-Add user samples to the click section, remove user samples from OSC section if necessary.
          -Add OSC/CLICK crossfade parameter (perhaps in both OSC and CLICK voice menus for convenience)
FILTER-add TILT EQ (two parameters, freq and tilt) LP and HP filters sometimes cut too much life out of the sound.
LFO - work on the modulation of Panning, currently modulates only 50% right and left if Panning is centered.
STEP - Copy currently selected step to another step
