Hello.
My problem is that if i have a sequence running then when i turn a knob a big faster or even a bit stronger and the lxr moves a bit it crashes the display the display stops working but the sound is still 100%. The knobs still works but i cant see anything on the display
What would you recomend? its a cold solder what do you recomend?
thank you so much
