Trigger i/o menu unavailable.
edited May 2015 in Troubleshooting
Hi
I have an otherwise completely functional LXR with trigger i/o board. I follow the instructions in the manual to access the trigger i/o menu (Shift + load/save to get to 'settings' menu then press 'AEG') but no menu appears. The board to board cable is installed correctly according to the trigger i/o build instructions. As far as I can tell the trigger i/o board is correctly assembled (the LXR worked first time after I built it and it's way more complex).
Has anyone got any ideas?
Thanks in advance
  • edited May 2015
    Just scroll with the encoder to the trigger related settings in the menu. The AEG button have no effect here. I think the description is from an old firmware.
  • Thanks for that, was just browsing the technical details and features area and found the same query and response.
    Godric
  • I updated the description on the trigger io page. :)
