Good afternoon Julian,
I have been following your project closely and already read the user manual a few times even though i don't own this jewel yet ![]()
In the future, is the sequencer going to grow to 64 steps for instance, instead of the current 16 steps?
Many thanks, I can't wait to feel it!
Stiiif
=P~
also it is mighty solid with its timing.
With all the sub steps a pattern is quite big. At the moment a pattern set of 8 patterns is about 50kbyte that have to be stored in memory. (8 patterns with 7 tracks à 128steps)
So I'm not sure if 4 times the data would still fit into the free memory.
Another point is loading time. I first want to try to speed up loading times before even considering this.
I already have an idea for faster pattern loading times, but it is a rather big rebuilt of the loading mechanism.
Another option would be a mode where you have less sub steps and more main steps, I am just wondering how one could fit this in the UI?!
@julian without the substeps - shift+those buttons could select groups of 16 steps (?) with flashing led to know which group was selected.
i vote for faster loading over more steps anyway
@dlyline: Personally i won't use an external sequencer even though it would work perfectly fine. Slowing down tempo is also a good trick but still feels too DIY/bending to me.
The more I think about it the more Im convinced about the power of chaining pattern vs 64 steps. Loading time is definitely a plus and the full visibility of the pattern steps (16 steps in this case) too.
If you have 64 steps, you would need to do an extra manipulation, press a button, in order to edit the 17 to 32 steps.
Still I can't get out of my head that more steps can only be positive to rythm creation!
@Julian: thanks for your technical point of view that makes so much sense.
i think in general it depends on your way of doing thing / style of music / etc. if more steps per pattern or chaining works better. but i have the feeling once you try the LXR a lot of you will be satisfied as it is.
i am always craving for more features in diy gear, too. but wanting more steps has not occured to me with this one.
there is just so many ways of adding variation to patterns.
not only chaining and substeps. wait till you try step probability. also don't forget different tracks can have different length. make the hihats 10 steps / pattern and you basically get a 80 (5x16)step pattern for example.
combine all those + twiddle the morph knob = BAM!
@loderbast: you are right, maybe you could share a quick videos on this specific matter --> no need for 64 steps!
unfortunately i have no camera here right now.
will see what i can do over the weekend.
