Hi!When I change the output to a single voice on the page mix, the sound continues to feel in all four outputs. So the entry is not directed in the individual outputs L1 R1 L2 R2 .The only difference is, in the stereo mode the sound is lower than the mode L1/R1/L2/R2. Suggestions?
if no cable is inserted into the selected out, it routes the signal to the next out were a cable is connected.
so you could make patches where the highhat is routed to out2 through a reverb and save the routing.
If you want to use this patch with a single cable connected you don't have to manually revert the routing to channel 1. but as soon as you re-connect a 2nd cable it will be re-routed automatically to out 2.
