Hello,
the short version, i have connected the penrose like a dum the first time.
I ask myself if have broken something? Cause when i try to calibrate it, the octave of my oscillator isn't changing when i put some cv source to the cv in of the penrose. And the note range seem's to begin on E and finish on D pushing the buttons on the penrose. When i push on E this button always plays a note he never come green, always directly red, strange(or not?). All the other things, gate out, trig in, work good. Any idea?
- how is your penrose connected to other modules for testing? just something like an LFO/manual CV to CV input and the CV out to an oscillator?
- the LEDs and buttons are working?
- the CV out does not change at all with all buttons active and an incoming CV?
you will hear a faint 'click' once the trimmer is at its end.
but the trimmer only adjusts a small bit of the CV range. so even if it is set to max/min you should hear changing notes. So this should not be a calibration problem.
since your OSC is reacting to button presses my guess would be that something with the CV input is wrong on the penrose module.
- what output voltage do you measure on the CV out with nothing connected to the CV in?
- Is the red LED moving with all buttons green and an incoming CV from the LFO?
- with a constant CV on the input. for example 5V, what do you measure on pin 23 of the AVR (alternatively pin 1 on the MCPO602.
here is the schematic:
http://www.sonic-potions.com/public/PenroseQuantizerSchematic.pdf
the CV in signal flow is:
on the top pcb
CV jack -> R15 (100k) -> TL072 (U2B pin 6) -> JP1 connector pin 8
bottom pcb:
JP2 connector pin 8 -> R7 (100k) -> MCP602 pin 2 -> AVR pin 23
