I was playing with the LXR today and think that I encountered a bug. At some point I had the feeling that everything was slightly off time, and when I went back to add some steps on the sequence, I noticed that all my hi hats were on the second substep instead of being on first like they were supposed to. I'm not sure what caused the displacement, but just before I realized the timing displacement, I was playing with the shuffle (and went into extreme settings and back to 0 quite fast) on a sequence where tracks weren't the same number of steps. I'm not sure that this is what caused the displacement though, but I'll try to reproduce it to be sure.
Anybody had a similar bug show up?
I did find out another bug though... It seems that if I create a sequence where all (or near all) the steps are on on one track, in voice mode, when I hold shift to insert substeps, the substeps won't actually light up correctly. I hold shift and then switch from one step to another, but the substeps will often not light up or just some of the "on" substeps will light up. This one I can reproduce.
For reference, I use a 9v, 3Amp power supply.
