I noticed the frontpanel pdf is larger then the fcd72 case design files. I was designing a case myself on basis of that pdf so i checked it with Franks files and they are really different.
This is the usual "can i send you some drawings and you cut a case of it" problem that mist programs dont really scale 100% in each direction + the fact that my Laser's Software doesnt scale exactly 100%, too. Inkscape does an especially bad job here.
The .EPS is exported directly from Corel, the .PDF is generated from this thru MacOS Preview, so i expect them to be 100% the same - what Program are you using to read the files?
Any news ? i tryed to convert the .ps as a drawing, but it can't scale correctly. i'm using catia v5 at my job. (that the problem with vector models....) If you can give me some information about the dimensions, i can maybe reconstruct it as a drawing.
Wow, I didn't know about that PDF. (sorry "dlyline" - must have overseen this while in a hurry ...) As far as I can measure this one seems to be the right proportions. I can also confirm that it doesn't line up with the .eps julian posted here earlier. The .eps is not wide enough while already being to high, so you would need to scale it disproportionately to fit the PDF. Maybe Corel messed up with the export ..? Had this problem quite sometimes before.
Maybe I could do a new EPS based on the PDF dimensions - but I would need to do it at the office and I'm on a day off today. Neither Illustrator nor InDesign is fun on a 13" laptop with trackpad only
fcd72 made the .eps file. Since he did the design for the enclosure. So I can't help here :-/ I measure the width of the fronpanel at 27.3cm and the height at 14.1cm
These are the dimensions of the actual cut out frontpanel? I didn't order a case yet, so I cant measure this myself. If I measure the .eps its about 271x143 mm. Scaled proportionally to 273 mm it would be a height of 144 mm so it sadly doesnt match the 141 mm... If I render the eps and the pdf and do a quick overlay I get the same result as shiftr already posted (I did align the upper left drilling hole) Seems like something went wrong somewhere on the way ...
@dlyline: please note that the hole sizes in the PDF are just estimates ... not 100% correct. But the centers are accurate. Guess thats all that matters ...
If you use the provided button caps those holes should be ~9mm, pots/encoder ~7mm (too big in the PDF but doesn't matter because the knobs would cover it), LEDs ~3mm, case screws ~3,5mm. At least thats the diameters I used and its a nice fit.
EDIT: updated the PDF with a size legend but forgot to actually scale the holes accordingly. The hot weather is melting my brain ...
I just drilled my own frontpanel using the pdf julian provided as a drill-template. i had to reverse the colours and print it at 101%. otherwise the measurements wouldn't have fitted properly.
i think it turned out quite good.
It's obviously not as tight a fit as fcd72's cases but it works.
So can i conclude that the pdf posted by julian is right? I used the files from Frank to cut a case but it came out exactly as off as in the comparison. It must be the scaling from Franks laser cutter.
I'm planning on making a new one on the basis of the pdf.
Hey Shiftr, did you do the real mesurement of the LXR, i'm doing a dimentionnal drawing, that i will put here soon, But if you have something to share !!
Here is the design i made in Illustrator. I think it's ok but it's not tested yet. I started working from the PCB PDF and did some real life measurements to confirm some stuff and for the outputs. It's very similar to franks case. I alway borrow some of parts from his shruthi design.
I hope i have some time next week to go to the fablab and make it on a laser cutter.
http://www.sonic-potions.com/public/SP_LXRCase_062.eps
Is there is a dxf, dwg or even a dimensional drawing for the front panel - i might make a custom case or front panel?
Looking forward to getting started on this build - congrats on a cool project.
BLOKE
http://www.sonic-potions.com/sites/default/files/assemblyInstruction/SP_Frontpanel.pdf
I measure 9.5mm holes for the buttons
Thanks ! Bye !
Looking forward to see some custom cases
