Short was measured using a multimeter and the beep test.
Sorry, perhaps I wasn't clear. At the initial voltage test after finishing the power supply I read 5v. After constructing the rest of the board, I did the continuity test, and discovered a short. However, I plugged it into the power supply anyway (I like to live dangerously), and I still read 5v....
Resistance between ground an 5v at the point in step 16 is a little less than 1 ohm. The only other point on the board which has the same behaviour is at the display connector between pins 1 and 2. Which I guess are ground and +5v?
ICs are not inserted yet I guess? hard to spot tiny solder bridges on the picture you provided... but my guess would be that'S what causes a short.
maybe try to reheat suspicious looking solder joints and make sure no solder joints touch their neighbours. resistance between gnd and 5V should be at least a few hundred ohms
if there is a short your voltage test would not read 5V.
what is the resistance between gnd and 5V?
I'll have a closer look on your picture
like the upper left 2 pins touching on the pic.
#-o
Glad it is solved.
