I've recently finished my LXR, the build went very well and worked perfectly first time. I have also added the Trigger IO option with both V and S trigger components fitted. I'm using a 9V 600mA power supply.
I have noticed that the voltage regulator heatsink gets rather hot, not hot enough to indicated there is a hardware problem but hot enough to concern me about the long term reliability. It's almost to hot to touch, I can touch it for an extended period but if it much hotter I wouldn't be able to.
My initial thoughts were that having both the S and V trigger transistors Intalled would be increasing the power consumption demands placed on the voltage regulator. I disconnected the trigger IO PCB to see if that made a difference but the heat generated did not change.
I think I'll just intall a bigger heatsink but I would be interested to know how hot other people's LXR heatsink get assuming they have a correctly assembled unit.
Rowan
9V - hot, still able to touch, but quite hot (also depending on how many LEDs are on)
In general one can say as long as you still can touch the regulator it is ok.
If it gets too hot it will shutdown itself.
Electrolytic caps next to it are in general ratet to 105°C
If you are really concerned use a 7.5V PSU
