One led on the sequencer blinks a few times and does not work.
edited January 2015 in Troubleshooting
Hello everyone,
My Lxr is working fine, all the knobs is working also the voices is great. I did a 30 minutes test playing around with it and its fine.
The only problem is that LED number 5 on the sequencer part is not working properly. When i press it, it starts to blink so it works one or twice then it stops to blink and there no light on it... So basically number 5 dosent work.. what would you suggest its wrong?
I just uploaded a video showing the problem
thank you
  • Can anyone pleaze help me.. thank you
  • sorry for my late reply [-O<
    so the step is working and only the LED is wonky?
    you can turn the seq step on and off regardless of the LED state?
    if you take a look at the schematic on page 7 :-B
    http://www.sonic-potions.de/sites/default/files/documents/FrontpanelSchematic.pdf
    Step 5 LED is connected to U7 (74hc595) pin 3 and RR2 (220ohm resistor network) pin 5.
    So first of all check the soldering on those 2 pins as well as on the LED itself.
    My guess would be a cold solder joint or a short somewhere to a neighbouring pin.
  • Hello Julian, what do you mean by a short somewhere to a neighbouring pin?
    To solve the problem of the cold joint, i can solder again on top of the place where theres already soldering on it?
  • regarding a cold solder joint - just reheat the solder joint without applying more solder. The point is just to re-melt the existing solder. Sometimes it looks as if the connection is good, but the solder has not completely melted to the part and has bad contact.
    quite helpful
    https://learn.adafruit.com/adafruit-guide-excellent-soldering/common-problems
    with short to a eighbouring pin I mean just to check if there is no contact to another pin next to it. like a little bit of cut of metal from a resistor leg or too much solder.
  • SOLVED!!
    thank you so much... i melted the solder then i pressed quite hard in each pin and now its perfectly working.. thank you
  • :)) \:D/ :-bd
  • youre are awsomeeeee incredible service...
