I'm not sure what I am currently reporting reveals to be a bug, a circuitry problem or a normal behaviour in v0.33, but I often need to hotplug so :
When there is only 1 jack plugged in any audio out (1, 2, 3 or 4), if the jack is hotplugged the LXR often crashes. It might to come from the brief short circuit happening during the unplugging.
Anyone is familiar with this behaviour ?
That's exactly how I test each mainboard before shipping it out.
I use a single audio cable and hot plug it into every audio out once and never had a crash.
Where is your jack conected to on the other side?
It's connected to an XLR audio out coming from a RME Babyface, external USB soundcard.
does it also happen with an unconnected cable without being plugged into your interface?
I'm quite impressed by your precision employed isolating the origin of the problem !
When it crashes the sequencer stops playing, the steps are erased and the kit is going nut. It doesn't seem to happen when the cable is unconnected on the other end.
so it happens when the plug is half way in, probably when it shorts the outs to gnd inside the jack... :-?
maybe there is a short between the plug detect switches and the AVR reset line?
could you check the soldering on P2 on the mainboard connector?
Pin 12,14,18 and 20 are the switch detect lines.
Pin 15 and 17 are AVR and mainboard reset.
I have to think what else could cause this...
@julian I'll check the soldering then.
@nightworxx I'm plugging into an external USB soundcard and indeed there is this fake connexion behind: the sound card input are balanced XLR, so the cable I am using is XLR on one end and RCA with jack adapter on the other end to connect the drum machine.
Do you think that would be the cause of this behaviour ?
@julian : I finally checked the soldering, which seem fine, visually at least. In order to do a deeper check, I need you to help me how to count the pins. AVR is written on the board but doesn't seem to correpond to pin 15, no matter how I count. Where should I start and follow the pins counting ?
