I've been trying to get this to work for a while now. Sort of driving me a bit crazy.
If I boot up the lxr and try to trigger the lxr via ableton drum rack, it appears to trigger all the voices at the same time. But any changes to the voice channel or Note parameter means no sounds at all. Very strange.
Can anyone help?
Check for the midi filtering parameter first, then carefully assign each voice to a specific note. Set up all of them. Don't forget to save your preset (the note setting is preset dependent and need to be parametered on all your presets if you wish to sync em all with ableton)
Everyone has different needs and setup.
