Since i upgraded to my Girts enclosure, two of the buttons (step & mod) have stopped working.
To make troubleshooting a bit trickier, i can no longer access the top of the main board as it's glued to the light pipes.
Not sure if things went south when I was re-soldiering the light diodes in a bit lower, or when i screwed the case onto the board... but either way, those 2 buttons no longer work.
Any suggestions would be much appreciated as my LXR's a bit unusable at the moment - bittersweet moment given how good it looks in its new enclosure.
GAH
not much that could be wrong.
- step button (from voice, perf, step, load/save group) is attached to U10 pin13 and +5V
- mod (from osc, mic, filter, aeg ... group) is attached to U6 pin 4 and +5V
here are 2 pics to show the connection
both can be done without removing the PCB from the enclosure.
Mod button is clicking just fine, but nothing happens...
I haven't got anything to check voltage with at the moment, but will check over the weekend.
But I think I won't have time before christmas for something like that.
did you measure if the button contact closes when you press it?
