Hey all,
I just finished assembling my new LXR. No problem along the build, everything wen smooth and it is fully operational. Already blown away after 10mn of playing.
Only thing is, I get weird symbols on the screen once in a while (like every 2-3 boot). When this problem appear, the unit appears to be working anyway (chaselight running).
Precision: It is a self sourced unit, but with the programmed Atmega from the shop.
Image:
http://forum.sonic-potions.com/discussion/311/23-display-and-running-light-problem-solved#Item_9
other thread:
http://forum.sonic-potions.com/discussion/142/no-led-blinking-after-soldering-but-only-strange-sings-on-lcd-solved#Item_34
maybe it is jhust a loose contact there.
Is the LXR still running when you jiggle it a bit?
as you said the strange symbols normaly indicate a reboot.
I guess the soldering around the display is ok.
You mentioned it happens every other boot.
If once booted correctly, does it still occur after a while, or is the only time it might happen during booting?
Thanks for your answer.
I jiggled the power connector, LXR is stills running.
It never happens when powered, it is always only on boot ( when I insert the power plug).
