triggerout hole sizing
edited September 2014 in General
hi,
i need some help.
i have a custom acryl case without triggerout holes at the rear panel.
at the moment i have soldered the trigger pcb and want add this pcb to my LXR.
i want drill the holes for trigger in/outs in the rearpanel, so i need the exact sizing and distance for the holes.
a scan or dxf/svg  file of the rearpanel would help.
  • As soon as I get my trigger board assembled (just ordered) I will try to help.... I'm in the same position almost.
  • I don't have the SVG for the backpanel here.
    I could provide a DXF file of the PCB and I can measure the hole size on one of the panels.
  • A dxf file helps.
    I can print it and fix it to the panel, its easier for drilling.
    Pls. Send to patrick@dsl-man.de
    Thank you
  • edited October 2014
    here is a zip with the exported SVG and DXF files from the trigger PCB:
    www.sonic-potions.com/public/trigger/triggerExtensionDimensions.zip
    these are the hole positions from girts backpanel - untested. this is from the latest sketch I have, but normally they should fit. maybe cross reference them with the DXF/SVG files from the PCB.
    www.sonic-potions.com/public/trigger/trigger_holes_untested.svg
  • Seems to fit with my trigger out panel I made (from a photo!)  for Shiftr's case.  Once I have my board installed and it is verified, I'll post my modified SVG.
