Hi everyone,
While reconfigurating my hardwaresetup, suddenly a burnt smell was noticable.
After a search it turned out to be my LXR that caused the smell.
Most likely the PSU of the LXR is dead. I got no 5Volt measurement as given in step 5 of the assemby instructions.
Could it be that the two capacitors are damaged ? They look a little brownish instead of black...
Any thoughts ?
Thanx in advance.
Jürgen
the capacitors look good.
they would bulge or pop if damaged.
I suspect the 7805.
the real question is why it happened.
what power plug do you use?
is there a short somewhere?
do you measure continuity between 5V and GND?
Thanks for the reply.
I used a 9v adapter, with the + polarity in center, which I bought for my guitarpedals.
http://www.sweetwater.com/store/detail/1SpotComboPk
I will measure for shorts and continuity when I get back home.
Jürgen
on the picture it looks like you already removed the ICs?
I replaced the 7805 voltage regulator, but I still don't measure 5Volt like indicated in step 5.
It did when I was building it and when I did the test before proceding to the next step.
The LXR worked fine 'till the accident..
Can't find traces of a fried component...
Jürgen
As safety precaution I will remove the other IC's as well...
A USB keyboard connected to the same hub has also died.
Is there any chance I could still repair the LXR.
I allready miss it a lot
Jürgen
seems it released its magic smoke.
the USB 5V line is connected to the STM32 chip (the big one)
and everything above 5V is really bad for it.
You can contact me via email.
I think I could offer you a cheaper replacement.
I still have some used mainbaords from some prototypes here if you are interested.
do you also measure continuity between 5V and GND when the mainboard is unplugged?
Fried mainboard and after a long search and reassemblage found out the 1N4148 protection diode for the optocoupler input was broken.
All my adapters are labeled from now on...
I'm surprised that it affected the diode.
The USB power is only used to detect if there is an USB cable plugged in and never forwarded to the frontpanel.
Seems the STM32 does not like 9V at all and wreaked havoc
Everything is working splendid as before and no data on the SD-card is lost.
Great !!!
Thanks for all the help Julian.
Jürgen
