Hello all!
My wise audio technician, my mistake corrector managed to find a short- before that all the parameters on the display were changing by themselves and the steps were switching on -on their own. Now that is all fine except the step mode. The parameters are still jumping in there. Could you maybe point to the direction where we should look for more shorts or other mistakes?
All help is greatly appreciated!
August
you only have jumping parameters if you edit step parameters like note, volume probability?
or do you mean something else?
or maybe a cold solder joint.
have a look at the schematic page 6
http://www.sonic-potions.de/sites/default/files/documents/FrontpanelSchematic.pdf
please check
U12 (hc165)
RR9 (10k network)
and the voice button.
regarding the "step" button.
you mean the 2nd of the 4 mode buttons?
normally the menu has nothing to do with the encoders/knobs.
they should either work everywhere or nowhere.
does this only happen while you hold down the button or the whole time step mode is active?
maybe the LED for the step mode has a short to the encoder or knob line?
