Problems with CC
hexhex
edited July 2014 in General
Hello!
I'm using my LXR for a while (with firmware 0.28) and i was lucky with it. Now i installed the new firmware (.34) and i have some problems.
My setup is: Logic Pro 9 with some external hardware (e.g. the Korg Padkontrol)
I configured the Padkontrol for playing the LXR with the drumpads - and the 2 extra knobs on my Padkontrol controlled the filter FRQ and the Resonance of each drum-voice. I switched up to 7 scenes in my Padcontrol to have controll over all 7 voices (FRQ and RES). I also was able to record the tweaks on my Padcontrol in Logic. It was really fun!
Now - i had to update all my drumkits - because the note setting in the Mix menu requires different notes. With the old firmware - I payed no attention with this parameter - all step note settings in each voice were set to "any" and it worked well. Also all voice channels were set to "0".
Now every drumkit have to be reworked with proper voice channels and with a proper step note setting (e.g. c1, c#1, d1, ...)
-> This is a lot of work - i have 96 drumkits... But its only a time problem ;-))
I can "upgrade" my dumkits - no problem but i didn't get the CC settings to controll the voices as before.
E.G. All drumkit voices have the midi channel 1. The global channel in the "Main" menu is set to 10. The midi RxFilter is set to all. My Padcontrol sends the CC messages on channel 10 and the CC--Numbers are corresponding to the  manual.
Is there any other setting i forgot to adjust?
It would be very nice, if sombody can help me!
And it is very important for me, because the LXR is the main part in my current production.
THANK YOU so much!
  • hexhex
    edited July 2014
    Update...
    I edit the global Midi Channel to 1.
    All voices channels are also set to 1.
    Now i can recieve the CC-Mesages from external gear (padkontrol).
    Curious... because the padcontrol sends the CC Meddages on Channel 10?
    but i works ;-)))
    by the way... LXR is the coolest drum machine ever!!
    Cheers,
    hex
  • i have a nanokontrol and a padkontrol to and i noticed that ther were some differences betwin pads midi's adress in korg kontrol editor and a DAW like Cubase or Live. when i program the first pad to play C1 and then i play this pad in cubase or live it plays C2 (or C 0 i don't remember).the problem comes from korg i suppose
