I experienced some digital clipping yesterday when using a lot of parts. Given the output level, it doesn't seem to be related to my soundcard (used as a mixer), but to the LXR.
I have found a possible cause for occasional clipping. Did the clipping only occur with all instruments playing or with a single instrument active as well?
I think I'll have to add a soft clipper to the mixer. sounds more fun than just reducing all the signal levels.
I just changed the mixer code a little bit. I hope the clipping will be gone now. The change will be included in tonights update. So please report any clipping that occurs after an update to firmware version 0.19.
i had this bug when i was using a lot of parts routed to the same couple of outputs at once, so it looks like it's in the mixer output part. By the way, the output of the synth is not very hot, I suppose that it's by design?
i have been very inactive recently and i'm really sorry for that. I shall do some testing again starting from next week.
I had enough to do anyways
