OK, so I assembled my latest build with the intention of using different LEDs but I installed the 'normal' current limiting resistor networks (220R) and now I need to pull the current down even further.
I've tried experimenting with a pot across one of the RLED connections but the behaviour seems peculiar - seems no matter what value pot I use I can't add enough resistance to get the LED brightness down. Is this a peculiarity of the bright LEDs (they're 'warm white' 750mcd)?
I was also wondering if there's a 'clever' way of maybe reducing the current going into/out of the LED driver ICs so that I could drop the current with just one added resistor per resistor network instead of having to install all 39 of the RLEDs.
Or, ultimately, am I going to just have to bite the bullet and desolder the 220R networks and replace with a higher resistor value?
adding additional resistors to R_LED wil always decrease the 220ohm from the network.
so either remove the networks (clip off GND connection on pin 1)) and put in higher value R_LED resistors. Or remove the resistor networks completely and replace them with a higer value network.
