External WAV-Sample Import
Is it possible and how to use own wav samples in the LXR (e.g. voices, or longer background files?
  • I remember that POD had explain how to load smaples (and I did it successfully) but I can't find anymore the thread in the forum :-(
    someone can give us the link to the explanation?
    We should work on FAQ I guesss !!!
  • edited July 2014
    can't find the original thread were julian explains it, but i found this:
    - you need a folder on the sd card named "samples"
    - put some 16-bit mono wavefiles in there (not more than 490kB!)
    - on the load screen there is a new option "load samples"
    - confirm with 'ok', make sure the seq is not running or the upload will fail
    - sample upload starts... this may take up to 30 sec. (not optimised yet)
    - when you see the "load sample - ok" screen again the upload is finished
    - the oscillators have some extra waveforms now "S1 to "Sn" where n is the number of samples uploaded
  • Hi loderbast,
    that sounds good and I will try this soon....
  • make sure you have the latest firmware, I had some problems importing samples with older versions
  • i manage to import some samples, but some are not working at all. this is weird cause all are mono, 16 bits and 44100 Hz but some work when some don't and i have no explanation
  • edited July 2014
    I made the experience that short one-shot samples with zero offset are defintely the best ones for the usage in the LXR.
  • problem resolved. the samples that used not to work were too big  [-O<  ~X(
    now that i use very short one-shot, there is no more problem :))
    i really love that machine :x this is a **==
    Thank you Julian!!!
