Change Pattern Via MIDI
Not a program change, I'd love to be able to change the playing pattern from a MIDI sequencer while the LXR is slaved, or queue up the next pattern exactly as pushing one of the pattern buttons in performance mode would do.
Thanks!
Brendan
  • It would be quite handy indeed...
  • YYYEEEESSSS, than I can change patterns from my Octatrack using midi prog change cc
  • This is possible right now, as I added the code to do so a long time ago. It will recognize a PC message and switch to one of the 8 patterns when the end of the bar is reached. The global midi channel (configured in the settings) is used for both sending and receiving the PC. If you send a PC > 8 it will just divide by 8 and use the remainder.
  • Tested this out from my MPC - confirmed, and is totally awesome. Thanks rudeog!
    This could use an add to the wiki though, it is not mentioned.
