I'm getting a strange bug with the parameter automation. Whenever i try to change a parameter, it seems to alter the corresponding step in another pattern.
I'll try making a short description to recreate that bug:
Create a pattern and copy it to the second pattern.
Chain them so that they are alternating.
Go to step-edit mode in the second pattern and automate a value.
On my machine it now alters that value, but in the first pattern. When you go to the first pattern now the same parameter is displayed.
If you change it it sometimes works and sometimes changes the value in the second pattern.
Also i noticed that when selecting a step in the step-edit mode, both the step and the substep are blinking (in sync when seq is not running and out of sync when its running) but the substep-blinking stops short after. If have the feeling that that is linked to the bug somehow.
I'll investigate further.
had a lot of other things to do this weekend.
I hope for the bank holliday on thursday to do the next release.
The fix will be included in the next update. maybe this evening, otherwise on the weekend.
