My step 15 LED was burned out, so I ordered another one. In the process of removing to faulty one, I seemed to have burned off the metal soldering pads. How do I go about fixing this?
You could follow the trace where the pad lifted to another soldered component and then solder in a little piece of fine hook up wire. Kind of like this...
these are the connecti0ons for the 2 pads. if it is the lower pad it is quite simple, because you could just use the R_LED pad next to it. for the upper pad wire is the way to go.
Thanks for the quick replies, guys. Both pads are gone, so I'll solder the negative lead to the RLED pad and wire the positive lead to pin 1 of that chip. The wiring diagram was exactly what I needed.
This didn't work... Could there be a problem somewhere else that would prevent only light 15 from lighting up? There's continuity between all of the points on each wire so it's properly soldered, and I know the polarity of the LED is correct.
hmmmm... it is on the first shift register in the chain, so I doubt there is a problem with the shift registers. otherwise the following LEDs would not work.
maybe have a closer look at the 220 resistor network RR1. LED15 is connected to pin 2.
there is not much more to the LED. U3/pin1 puts out 5V and is connected to LED15. the other side is connected to rr1/pin2 (resistor) which is connected to gnd.
Try downloading the latest firmware again. I had a similar issue. Led for drumvoice nr 4 died. I changed it and everything was fine for a week then it died again. Didn't have the energy to open the case and change it again so I let it be. When I a few days ago upgraded to 0.34 I suddenly started to work again. Now it's working perfectly. I can't really either understand nore explain but everything is fine now.
Could it have something to do with the leads going through the old holes? Could there be residual metal in there that would cause a short?
Another possibly related problem, when I turn the unit to the side (the top is perpendicular to the ground), the voice, perf, and step light get very dim and then go out. When I put the unit flat again, the lights go back to normal.
http://wiki.aussiearcade.com.au/images/4/4a/Pcb_repair_wardner_2_2.jpg
I'll give this a go tomorrow and I'll update.
there is no gyroscope sensor build in
regarding step 15
If it should be lit (step active) what do you measure on pin 1 of U3 (hc595)
